Ford Rs Parts For Sale (Not cosworth, or Cvh Turbo) All Ford rs parts for sale in here that do not fit in the popular Cosworth or Cvh turbo sections. Starting a topic requires you to have purchased a gold membership.
Major clearout, all sorts
Old Nov 27, 2012 | 12:20 PM
rs220bhp's Avatar
rs220bhp
Default Major clearout, all sorts
Think the time has come where i cant really find the time and enthusiasm anymore to have a car that constantly needs work doing to it or improving so have decided to sell all my spares as i will not have any use for them any time soon. There is a mixture or mk2 and mk3 fiesta items and alot of bits universal between quite a few car. I will be copying this and putting it up on other forums hence the different vehicle etc. I will get photos up of all parts when photobucket will let me upload them, other pictures are already on there
Collection from Woking or Byfleet in Surrey. Can post smaller items at extra cost but anything bulky will ideally need to be collected
Wheels
4 x escort gti wheels and caps in black with one good tyre. good condition and paint/powdercoat. £60
4 x escort gti wheels in black/grey with good 195/45/15 toyos, paint not in the best condition but all caps present £70
4 x tsw stealths with 195/40/16 toyo t1r's done about 1k max so still as new, wheels have some kurb marks but nothing major £180
2 x toyo t1r's 195/40/16 tyres new £100
2 x escort rs2000 wheels in silver with falken 195/50/15 tyres, one has slight wear on inner edge but main tread still has 5mm. other is good 5-6mm all across £40
2 x escort rs2000 wheels in matt black with avon zz3's with around 5mm tread 195/45/15 £40
5 x team dynamics pro race 1.2s 7x15 et35. 2 have good tyres with around 5mm tread, other 2 are just about legal but would do a track day or 2. other wheel has no tyre £180
Management
Omex 600 with race prepared loom for zetec turbo. comes with new water and air temp sensor. Will need mapping for zetec turbo as currently has st170 with throttle bodies map £550
omex 600 loom and connections for st170 with jenvey throttle bodies. £100
Zetec turbo bits
Wosner 86mm pistons and pec rods for silvertop. Rods and pistons are currently fitted together but never been used £700
focus rs turbo and manifold with oil feed. very little play in the shaft and in perfect working order £250
Rs1800 complete HO inlet manifold with sandwich plate etc £80
Eagle h section rods £300
Engines
Fully rebulit 2l silvertop zetec botom end. Rebuilt by brett simms including lighten and balance bottom end, bore and hone cylinders. fit 0.5mm oversize standard cast pistons, arp rod and flywheel bolts. New bearings and baffeled sump £450
2L silvertop bottom end and head. was going to be used for zetec turbo. no cams etc £70
Escort rs turbo bottom end in good working order. came from a running car. Just needs head bolting back on and its ready to run £15o
1.8 zetec from escort gti, good runner or use for 2l conversion parts £100
Escort rs turbo engine rebuilt 10k ago. has ported and polished head, new kent cams kit and vernier. new genuine ford head gasket and water pump. arp stud and nut head bolt conversion £600
Cossie t3 on escort cvh manifold. little play in the shaft. Good working order. Has slight cracks around wastegate like they all do £175
Hoses
Various samco hoses in blue just sraights.elbows and joiners. Offers on individual hoses or £120 the lot
Samco and sfs boost and water hoses for escort rs turbo/fiesta turbo t3 conversion. Some trial fitted but never run £180
A set of hoses and alloy joiners for fan stat and other sensors. In black from shane for a mk2 fiesta with zetec conversion. Also included is an alloy thermostat housing that has been modified to have a turbo feed coming off it. never used £175
Seats
2 x omp wrc bucket seats with side mounts and omp 4 point harnesses in blue. Never been used but seats have a few marks on the backs from storage. All in fia date etc from 2011. £450
2 x escort 90 spec recaros with mk2 rear seats retrimmed to match. All in very good condition £250
General bits
Gizzmo ibc boost controller. This is the 3.5bar 6 settings version £120
Pair of LMA quick release 3 point harnesses £40
Nomad white faced boost gauge £20 mk3 pod £20
infinity 6x9's £15
Superchips boost gauge £10
Fire extinguisher £15
Mk3 bits
Red bonnet with louvres pressed into it. Will need paint £50
front and rear bumpers, will need paint or very good mop/polish £40 front £15 rear
Rear rs turbo spoiler x2 both red £20 each
side skirts and arches £30
Spax suspension kit, shcoks and springs £60
Front hubs £30 pair
Front calipers and carriers rs turbo £15
openeing rear quaters, unetched £20 no rubbers
Spax coilovers with remote resevoirs. These are the real deal, compare the size of the front pistons with the likes of even the gaz golds to see the difference. Rears have rose jointed lower mounts. Come with adjustable top mounts £350
Rs turbo k+n induction kit, brand new £30
New light and indicator stalks £20
single wiper conversion £30
Black and grey double gauge pods £20 each
Powdercoated mounts £30 the lot
mk3 zetec front strut brace by Sparco alloy £60
RS1800 CULT ecu in perfect working order £70
Complete inlet minus injectors £60 or with grey vw 210cc injectors £120
Si front bumper with cossie bib and laguna splitter £70
MK2
Omp front strut brace £25
B+M shifter with mk2 linkage £225
Custom gauge pod blended into top half of sterring surround £45
new front and rear door cards and parcelshelf offers
Brand new boost spoiler £120
New speedo unit £15
Will be adding more as i think of bits of come across them in the garage
Old Nov 29, 2012 | 07:54 PM
MunchieS's Avatar
MunchieS
Are you selling the wilwoods? 300mm?
Would be interested..
Old Jan 5, 2013 | 08:36 PM
Stuckey's Avatar
Stuckey
do you still have your Infinity 6X9's ??
thanks
Old Jan 7, 2013 | 08:27 PM
dingla rs's Avatar
dingla rs
16mm hose how much cheers
Old Jan 8, 2013 | 08:57 PM
Some good parts there.
Old Jan 21, 2014 | 08:10 PM
xr2brett's Avatar
xr2brett
Are the eagle h section rods for blacktop or silvertop zetec ?
boeb
Jan 9, 2020 05:11 AM
IainRS1700T
Sep 25, 2015 06:44 AM
hopper350
Sep 4, 2015 12:53 AM
