Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
CHT Sensor
Old Nov 22, 2012 | 03:01 PM
wwwdot's Avatar
wwwdot
Default CHT Sensor
Can anyone tell me how to remove the CHT sensor on a 2002 1.6 Focus ?
I pulled the grommet out from between 2 & 3 plugs but can't tell wether the leads pull off from the sensor ( is it a plug on top or is it part of the sensor body )?. Does the camshaft cover need to be removed as a socket will not go over the plastic socket on the replacement I have just bought.
any help appreciated
wwwdot
Old Nov 26, 2012 | 12:48 PM
martysmartie's Avatar
martysmartie
The connector pulls off and you will need a long reach extension, (like you would with the plugs) to remove it.
Martin
Old Nov 30, 2012 | 04:33 PM
wwwdot's Avatar
wwwdot
Cheers Martin
I was given the wrong sensor at the accessory shop, which threw me. I have since done it and it was straight forward. Car is now back to normal.
Thanks for taking the time to reply
Old Dec 1, 2012 | 11:07 AM
martysmartie
No problem, glad it's sorted.
Martin
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
