Ford Puma Discuss the Ford Puma here!
Rear axle shims?
Old Nov 17, 2012 | 10:36 PM
haggis666's Avatar
haggis666
Default Rear axle shims?
I read on a thead earlier about shims on rear axle but cant find it again would it be wheel spacers to widen the track on rear or axle geometry?
Old Nov 17, 2012 | 10:50 PM
fraser9764's Avatar
fraser9764
Removed
Old Nov 18, 2012 | 06:37 AM
haggis666's Avatar
haggis666
Originally Posted by fraser9764
I think you mean geometry correction shims. Mike rainbird does toe shims which give a small amount of toe in on the rear, these help with tyre wear and give them rear a more centered feel. Either them or these camber shims that are floating about, the just change the rear camber to correct for lowering springs etc. The only way to do it properly though is a six degree rear beam, although you are talking a good amount of money.
Is that the s1600 reae beam?
Old Nov 18, 2012 | 10:26 AM
haggis666's Avatar
haggis666
What other chassis/suspension tweaks help Im thinking of one for targa rallys on tarmac aerodromes? Its a puma or mx5 Im looking into at mo
A mx5 came 4th overall and the puma entry came second last but that might be down to the driver.
Old Nov 18, 2012 | 10:30 AM
fraser9764's Avatar
fraser9764
Sorry I didn't realise I was somehow in the puma room, ignore my previous reply
155lee
Sep 6, 2016 11:10 AM
CrOwSoN15
Sep 14, 2015 11:33 AM
The Enigma
Sep 12, 2015 10:12 PM
grishenko45
Sep 9, 2015 12:58 PM
cossirob
Sep 3, 2015 09:17 PM
