2wd cosworth rebuild
hi to all i am rebuilding my 2wd cosworth engine and wanted to use a 4wd oil cooler/modine but it has a wider body than a 2wd one so the bolt is too short to reach the thread attacthed to the block, i have looked at 4wd oil cooler bolts but these totally different as the 4wd cooler bolts to a remote housing, any ideas how i can get around this or is it a case of getting a 2wd cooler? also i have noticed that 2 long wires where tucked behind the battery coming out of the wiring loom that are one brown wire and one black/purple? i have looked at a friends 2wd saff but these wires have just been cut off? any ideas what they are for? many thanks to all who reply and have fun in whatever you are doing with your fast ford
Oct 9, 2015 07:38 PM
FlashRS
13
Aug 31, 2015 06:02 PM
Aug 14, 2015 07:29 AM
