L8 on 3door
Old Nov 14, 2012 | 09:07 PM
daz1968's Avatar
daz1968
Default L8 on 3door
I am hoping to fit a l8 ecu to my 3 door over winter and take advantage of closed loop fuelling and knock sensor. I will remove my engine loom and add wires as required to the loom. I however need a little advice as to type of cable to use for the lambda and knock sensor, also the connections required. It appears on bigturbo.com that the knock sensor may be shielded but if so were do I connect the shielding and if one or both ends. Any advice appreciated as I am hoping to get my loom off shortly and check it over before adding extra wires. I may even incorporate my wasted spark in the loom and do away with the add on loom.
Thanks
pugo
Jan 14, 2006 04:37 PM
chriswrx
Nov 11, 2005 10:08 PM
Gaaables
14
Dec 29, 2004 06:21 PM
CozzyBrom
23
Oct 5, 2004 03:08 AM
CozzyBrom
Jul 14, 2004 06:05 AM
