Sierra Cosworth 4x4 Diff Ratio Question
Old Nov 13, 2012 | 05:36 PM
S80RTE's Avatar
S80RTE
Default Sierra Cosworth 4x4 Diff Ratio Question
Hi can Anybody tell me the number of teeth on the pinion gear and the crown wheel that are used to get the 3.64 ratio ?
Old Nov 17, 2012 | 11:05 AM
Dave2302's Avatar
Dave2302
Tranny Man
Front or rear diff, and why do you need to know this? (as I'll have to tke a cover off one to count them), maybe I can give you advice without doing this ?
Obviously you must use the same Front and Rear on a 4X4 Car.
There is a 3.9 ratio which is from the 2.0 Sierra 4X4 which I am using in my Puma 4X4 Front 3.9's are getting hard to find now
HTH Dave
Old Nov 17, 2012 | 12:39 PM
dojj's Avatar
dojj
Resident Wrestling Legend
i've got 2 of the front diffs and no one wants them, even for free
Old Nov 17, 2012 | 04:30 PM
Dave2302's Avatar
Dave2302
Tranny Man
What 3.9 fronts ??
I'll have them off you if so
Cheers Dave
Old Nov 17, 2012 | 09:15 PM
S80RTE's Avatar
S80RTE
The reason I ask is I am doing a 4x4 conversion on a MK5 cortina and I am thinking about using the original rear axle and a quaife ATB diff. So I am trying to find on the teeth on the pinion and crown wheels on a 4x4 cossie diff so I can get an identical set for the atlas diff.
mk3 fiesta cosworth
Aug 23, 2015 10:31 AM
charliecosworth
Aug 19, 2015 02:00 PM
cossie4x4
Aug 14, 2015 06:29 PM
155lee
Aug 14, 2015 11:21 AM
dal3door
Aug 13, 2015 06:55 AM
