cost to change cambelt on an ST 2.5
Just helped source a 2.5T ST model S-Max for a mate, will need to get the cambelt done right away as its recommended at 125k and this one is already at 99k (2008 model).
Anyone done one on these how many hours to do it and how much is the kit (or how much did you get charged for the job?
Anything other common known issues on these at big miles?
How do you lock the cams and crack up.Do you have to take the cam shaft cover off like you do with the zetec engines.
Thanks for the replies £200 sounds fine does not look like there is a lot of room in there to do this job.
Yeah the MPG is not great - but its a 220 bhp van that is not far off the size of a transit.
However its far cheaper than buying the equivalent age/spec sh1tbox diesel version and for a low mileage user like this it makes a lot of sense.
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
