Getting a key cut for my Escort Cosworth 1995
Old Nov 11, 2012 | 04:05 PM
booner999's Avatar
booner999
Default Getting a key cut for my Escort Cosworth 1995
Hi all,
I only have one key for my car and need to get another cut as a spare.
The key I have is plain black, no colour at all, no chip markings etc.
It will only be used for the ignition as the car is de-locked....
Do I need a key cut and programmed or just cut?
Where can I get this done and how much should I be looking to pay?
thanks
MArk
Old Nov 11, 2012 | 04:32 PM
Bloomers's Avatar
Bloomers
Cornish Fasty
if there is no chip should be about 5-10 quid
Old Nov 11, 2012 | 04:35 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
try to get a gen ford blank or even a torch key then have that cut
Old Nov 11, 2012 | 04:38 PM
turboRS's Avatar
turboRS
C16OSY
As far as I know if its a plain key then all you need is a normal key to use it. Easiest way to find out is remove the ignition cowling and if it doesn't have a transponder ring around the ignition barrel then all you need is a plain key! Should cost approx £15-£20 supplied and cut from any motor factors or even main dealers I would have thought but don't quote me on it!
Old Nov 11, 2012 | 05:03 PM
booner999's Avatar
booner999
OK guys,
Sounds good then. I will call Frauds tomorrow and see what they can do. Then I will phone others and compare
Vincereese
Jun 1, 2023 09:14 AM
jessie_rs
11
Jun 3, 2019 04:57 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
Old ford
Jul 31, 2015 06:50 AM
