Focus locks
Old Nov 10, 2012 | 03:19 PM
rs graham's Avatar
rs graham
From: In the pub cheering on Ricky hatton and Joe calzaghe
Default Focus locks
My focus has no central locking and the key fob also don't work ?
Fuses are fine.
Old Nov 10, 2012 | 04:25 PM
H3lsing's Avatar
H3lsing
ffoc.co.uk
At the rear of the glove box fusebox there is a fuse for the central locking f63. It's a fiddler fecker to get to but possible. I think the panel is held in with 2 10mm bolts.
If the fuse is ok then the micro switch inside the central locking module in the drivers door will be the culprit. Moisture and water make their way past the seal and drip onto the module causing it to short.
If you want any more info on it just google; focus central locking finally a solution!.
Mile30
69
May 13, 2017 08:44 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 08:57 PM
richierich1986
Sep 18, 2015 03:29 PM
Flatlinedan
Sep 18, 2015 12:41 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
