Evo brakes on my cossie
Hi peeps i have recently dumped the jap scene and come back to the good ol headache of cossie's, im trying to find out though if anyone has fitted evo brembo's to a 4x4 cossie, and if so was it a hastle of a job to do, any info would be great they are going to be fitted with the RS7's.
Check coleyst200's thread in the resto section he has fitted them to his focus running full 4x4 drive train.
I'm sure the bracket to carry the caliper is pretty straight forward to make .
Think there's a little Dremel work for clearence on the caliper
David
David
Are they the type found on the Evo 5-9? The ones with the 320mm front disc and 300mm rear I believe.
Same as I have ready to fit to my fiesta - the rears have no handbrake mech, so that's something to consider.
I'd have thought a mk1 focus RS disc would work on the front. The spacing on the mounting holes is different to the RS Brembo's, so don't try using brackets for those.
As said the RS 7 spokes are a nice wheel but even the std 2wd brakes require a 5mm spacer for them to clear so many aftermarket brakeset ups will just not fit.
Regards
Paul
The Enigma
Sep 12, 2015 10:12 PM
