focus tddi snapped cambelt
Hi all I have a 2001 ( y reg) focus 1.8tddi that has decided in its wisdom to spin the fuel pump sprocket on the rubber band they call a cambelt striping the teeth as it spun :-( right i have a P reg escort serenade 1.8td and what i want to know is will the head from the escort fit the focus as i'm 95% sure they are the same engines with exception to the fuel systems but my main worry is obviously will the water/oil ways-gallerys match ? will it be a straight swap considering its going onto a tddi from a td any help will be greatfully taken on board cheers OLI
