escort cossie front anti roli bar on 2wd sierra cossie
Old Nov 5, 2012 | 02:26 PM
Thanasis's Avatar
Thanasis
Default escort cossie front anti roli bar on 2wd sierra cossie
Hello does anyone has placed front anti roll bar on 2wd sierra cosworth?if so is that better? thanks a lot
Old Nov 5, 2012 | 09:21 PM
Marc sierra's Avatar
Marc sierra
A 4x4 arb gives too much caster on a 2wd car, so I wouldn't suggest it. Why would you want to try, because of the 29 mm thickness? If so, the Granada 24v is also 29 mm thick and can be fitted. Although it's quite a nightmare to get in because it's a bit wider than the Sierra one.
Old Nov 5, 2012 | 09:40 PM
Thanasis's Avatar
Thanasis
yes for that reason,because is 29mm,i know about caster,i think it's good,i will try to find from Granada too,thanks a lot
nice_head
Aug 12, 2015 07:01 PM
track.focus'd
Aug 12, 2015 05:53 PM
Vincereese
Aug 11, 2015 08:44 AM
Graceland
Jul 31, 2015 10:34 AM
Old ford
Jul 31, 2015 06:50 AM
