Cosworth 4x4
Hi all, I have a Sierra Sapphire Cosworth 4x4. When I turn left I get a banging noise coming from around the gearbox area. I can feel it pretty harshly on the floor too. I’ve moved the exhaust as it’s quite close to the box but this doesn’t appear to have helped. Any thoughts? CheeRS Terry.
He means the propshaft joint, it's the front propshaft between the gearbox and the front diff you need to look at. Failing that i'd check both engine mounts are ok, and the cv joints of both front drievshafts.
Don’t know if this is linked or not, but my steering is extremely heavy at times. I’ve checked the power steering fluid which is fine. It doesn’t happen all the time either, once or twice its on full lock but the wheels have hardly moved? It just seems to be one thing after another with it!
Thanks Terry,
Thanks Terry,
Thanks Terry,
Thanks Terry,
It’s random. Sometimes it can be first thing in the morning, other times it can be as and when it feels like it. But this only seems to have happened recently. It actually feels heavier than when the car isn’t running and you have to steer. Really starting to get cured of it!
http://www.turbosport.co.uk/showthre...rth-4x4-Owners
The reason I remember to search for this is because my Mom always used to give me the Motoring section of the Daily Telegraph - in the 'Honest John' section which was a Q and A part there was a letter with a pic of an exploded Cosworth 4x4 gearbox where a guy had started off with similar symptoms. It had done a lot of damage to his car when it went. You rarely see anything about Cosworths in mainstream newspapers hence I remembered about it. The thread above is a similar issue ( I couldn't find any reference to the original Honest John article )
Not saying yours isn't something simple like the exhaust but it may be worth checking
To be honest I think it’s just a scrapper lol! Well I’m hoping to get it on a ramp tonight and have a look. So I’ll let you know how it gets on tonight, thanks for your advice (and worry!) LOL
Terry.
Terry.
Don't want to worry you but read this
Wow, i didnt realise it was that long i made that Turbosport post
I still have that cosworth,and the front prop has been fine since
Hope you got it sorted!
Anutternutter
Aug 21, 2015 06:07 PM
charliecosworth
Aug 19, 2015 02:00 PM
Aug 14, 2015 07:29 AM
