Loads of Cosworth parts - few new parts added
As my saph project is nearing completion I'm getting rid of loads of left over spares.
Prices do not include postage.
Collection from Northants/Bedfordshire fine.
Paypal or cash on collection only
Thanks
Brad 07951751795
Very good used throttle cable £10 *SOLD*
Powerflex rear anti roll bar bushes, brand new never used to suit 2wd 16mm rear bar £20
Samco boost hoses, good used condition £25
Brand new samco silicon elbow 76mm internal diameter £15
Aluminium air intake pipe in satin black with SFS silicon adaptor hoses £15
4x4 Rear diff, came on my donor shell. Appears fine £50
4x4 Rear hubs and flanges £30
4x4 Steering rack complete with coupling £40
4x4 Rear number plate panel, all fixing points in tact £15
Group A Coil £15
Rear light bulb holders (1st set) £8
Rear light bulb holders (2nd set) £8
Brake and clutch pedal assembly £15
RS 4 spoke steering wheel & boss (came off my series 2), could do with retrim £35 *SOLD*
Old style ford badge, few marks £5
Ford radio cassette player £15
Ignition amplifier £10 *SOLD*
PAS tank £5
Accelerator pedal £5 *SOLD*
Bootlid hinges £10
Bonnet catch £5
Rear ARB clamps £5
4x4 ABS ECU £10
Pair door mirror covers £10
Side skirt set without jacking point covers £25
Bonnet hinges £10
B Pillar trims £10
Offside clear indicator £5
Another offside clear indicator £5
Battery earth cable £8
Fusebox cover £5
Another fusebox cover £5
Brand new thrust bearing £10
Amber side repeaters (1st pair)£8
Amber side repeaters (2nd pair)£8
Bracket for steel panel between engine bay and scuttle panel £5
Drivers lower dash panel to suit cars with adjustable steering column (came off late 4x4) £15
Good used engine mounts £15
4x4 nearside rear light £15
Pair of rear light gaskets £5
Passenger lower dash panel (came off late 4x4) £20
GGR silicon water hoses £15 *SOLD*
Rear ARB 16mm off 2wd £10
Front ARB with brackets (off 4x4) £15
Wiper linkage £10
2wd nearside rear light £20
Pair door shut seals (upper) £10
Side window interior rubbers £5 each
Sunroof interior rubber trim £10
Fuel neck (off late car) £10
Pair radiator fans £10
Late type kick panel trims £10
Washer bottle £10
4x4 Master Cylinder £25
Brake manifold block thingy £10
Heater controls £5
2wd carpet in good shape £20
Set of door shut rubber seals £20
Clock £8
Blower motor £10
Adjustable steering column £20 *SOLD*
Late type fuel filler cap £5
4x4 oil cap £5
Header tank cap £5
HT lead bracket (just plated) £8
Gearbox cradle brackets (just plated) £10 pair *SOLD*
Brand new thermostat £7
Brand new oil pressure gauge line £10
Genuine Amber indicators, no damage £20 *SOLD*
2wd gearbox cradle, freshly powder coated gloss black £25
New 25mm silicon hose £8
Samco silicon hose £10
SFS turbo water silicon hose £10
Brand new auto specialists turbo water silicon hose £10
8mm silicon hose £10
Odd silicon hoses £3 each
Boot spoiler with caps £15
4x4 front crossmember (slight damage) £15
Sunroof panel £8
Nearside headlight £10 *SOLD*
Offside headlight £10
C Pillar exterior trims, all fixing studs in tact £10 pair
Standard diff mount £5
Oil pressure gauge adaptor £5 *SOLD*
Gear stick gaitor £5 *SOLD*
Indicator stalk £8
Fog light bezels £8 *SOLD*
Washer/Light stalk £8
Window switch panel £8 *SOLD*
4x4 centre console with rainbow cloth armrest £20
Used standard clutch cover £15
Boot carpet £10
Rear turret carpet trims (small cut outs where strut tops sit from previous owner) £10 pair
B Pillar lower trims £5 each
A Pillar trims £10 pair
Front plastic sill trims £10 pair
Nearside rear plastic sill trims £5 each
Offside rear plastic sill trims £5 each
Centre console cassette holder £5
Wiper arms £8 pair
Electric sunroof motor and plastic panel/switch/light £20 *SOLD*
Parcel shelf £8
Roof rails (no clips) £8 pair
Recaro seat runners £20 pair
Rainbow door cards in very good condition, no shrinkage £75 *SOLD*
Late 4x4 dash complete (has 3 holes for car phone) £30
Thanks
Brad 07951751795
Group A Coil £15
PAS tank £5
Bootlid hinges £10
Bonnet catch £5
Rear ARB clamps £5
4x4 ABS ECU £10
Bonnet hinges £10
B Pillar trims £10
Fusebox cover £5
Wiper linkage £10
Washer bottle £10
Heater controls £5
Clock £8
Blower motor £10
4x4 oil cap £5
Header tank cap £5
Sunroof panel £8
Indicator stalk £8
Boot carpet £10
Wiper arms £8 pair
Parcel shelf £8
Will you post the steering wheel and accelerator pedal ??
I would pay you via pay pal as a gift or bank transfer
Cheers jeff
Cheers jeff
Yes, still have spoiler, oil line & adaptor. Spoiler will be expensive to ship. Could send just the line and adaptor for £15?
I'll accept £15 for the new samco 76mm elbow posted. Will send you PayPal address now.
Thanks
Brad
Thanks
Brad
Thanks
Brad
