T38 TURBO new build, siemens deka 55lb injectors
t38 spec brand new core, 360 thrust bearing, new turbine shaft, new compressor wheel.
machined comp housing to take bigger comp wheel, machined exhaust housing for the bigger turbine shaft
good strong turbo will make good power with the right set up
will make an easy 400bhp and up to about 470bhp if wanted
only for sale as im getting a gtx30 to go with my new engine build
£700 + p&p
siemens deka 55lb injectors done less than 100 miles ! replaced with 83s for upgrade
£200 + postage
£700 + p&p
£200 + postage
big_Rad
Sep 15, 2017 09:36 AM
Danielbetty
Oct 3, 2015 06:01 PM
Matt Baxter
Sep 16, 2015 08:30 PM
