1989 sapphire cosworth breaking
Old Oct 30, 2012 | 09:08 PM
rossimk2's Avatar
rossimk2
Default 1989 sapphire cosworth breaking
With a heavy heart due to lack of time iam Breaking my 1989 diamond white sapphire cosworth, many new unfitted parts available full list as follows
Engine bay-
fresh rebuild on engine done 0 miles based on mint low mileage 205 block,new std size 4x4 mahle pistons&rings with valve cut outs, crank on std/std, arp rod bolts vanderval bearings, baffled g19 sump,surface ground flywheel new ap paddle clutch kit,arp stud&nut kit wrc cometic head gasket, head skimmed to clean,16 new valves,16 new valve guides, new ina tappets,mint std cams,isky double valve springs, lightly ported matched to manifolds,new alloy verniers,new gates cambelt kit ina tensioner,all gaskets and seals used are genuine ford refurbed rocker cover in radiant red re polished,as new t34.48 turbo, alternator,starter inlet, engine mounts , ready to fit all pro build by r.s.d, cost a fortune ready to bolt in all new all parts chemicaly cleaned £4000 ono
bailey powder coated black header tank £ 125
bailey water swirl pot powder coated black £80
bailiey breather pot polished £80
bailey 3 leg turbo damper polished £70
complete setrab oil cooler kit £100
new 4x4 header tank £40
ah fabrications rs 500 intercooler £150
mint std rad and fans £50
siemens blacks 55 lbs new £200
4x4 inlet manifold £25
std cam pulleys £25
group a r&b single bar strut brace £80
new msd wasted spark full kit inc twin amp bracket & coil pack bracket,dizzy blank cap new unused £400
samco black full water hose kit £70
samco blue full water hose kit £70
samco blue boost hose kit £70
roose 4x4 header tank - 2wd coversion pipe blue £25
3 bar map sensor£40
4x4 cam belt cover £40
New unfitted vibra technics engine mounts £180
mongoose complete 3"exhaust with 4"tailpipe £150
new genuine bosch 044 pump&fitting boxed unused £160
Transmission
2 wd t5 box bellhousing, stick,&mount ready to fit excellent £375
new unfitted vibra technics 2wd gear box mount £80
suspension, steering& axle-
koni adjustable front &rear 2wd done max of 1000 miles £325
leda bajoo road springs as new done less than 500 miles £125
powerflex top mount bushes as new £25
perfect 2wd tca's with as new powerflex bushes £ 60
2wd front hubs with abs sensors perfect order £80
2wd front arb with powerflex bushes and clamps&bolts £50
scorpio cosworth rear arb 21mm with ford bushes&clamps new ford drop links £100
engine cross member std engine mnts £45
power steering rack complete with pipes perfect no wear £40
new unfitted cdf alloy rack mounts £25
Complete rear axle silent diff new genuine ford rosejointed bushes fitted in trailing arms all shafts &hubs ect ready to fit £500
as new done less than 500 miles group a type diff mount £80
rear group a polished strut brace £70
brakes-
front-350mm x32 brembo porsche 4 pot setup all complete done less than 500 miles braided flexi's £800
std refurbed 4pots with as new ferodo discs and pads perfect ready to fit£200
Rear-reyland 300x22 conversion kit as new using new genuine ford escort cosworth calipers all done less than 500 miles £500
std 2wd new calipers, ferodo dics&pads as new ready to fit done less than 500 miles £125
Interior-
very nice 2wd full black leather interior very little wear on drivers seat slight srinkage on door cards every thing included black dash& carpet ect £450
2wd clocks with white dails £25
2wd std clocks £40
auto meter boost, battery&oil pressure in heater vent pod white dail all fittings ect £100
mint 2wd steering wheel £60
Electrics-
New grp a fuel pump loom kit £35
As new fan loom £30
full engine loom £100
l6 ecu with stg 3 chip for greens t3 3 bar std cams £150
new msd chip for siemens blacks 55 lbs std cams t34.48 and wasted spark new unfitted £150
new unused msd complete wasted spark kit with twin amp & coil pack & dizzy cap blank everything you need £400
Wheels -
compomotive mo6 in silver 8x18 with 215x35x18 tyres as new done less than 500 miles mint £900
escort cosworth 8x16 std wheels still fitted with correct pirelli pzero tyres with 5-6 mm tread been dry stored 14 years mint £600
Body-
all parts in diamond white ready to fit
front bumper excellent with lamps&all brackets towing cover £175
Side skirts with all covers £130
4x4 mint bonnet with vents £150
boot with new badges spoiler £80
rear bumper with cut out for twin 3.5" with polished surrond £50
rear bumper in magenta very nice £70
all doors are perfect with side mouldings ect
very solid straightb shell hpi clear ect
rear tinted lights&surround £30
head lights £25 each
as new clear indicators £15
new boxed cdf alloy side skirt clips £100
**NEW genuine ford rear ambers light units new boxed £200
new genuine amber side repeaters £30
new lucus amber front indicators £30,
All parts in perfect order most less than 500 miles or new as stated, some of the parts are still fitted to the car it will be stripped this weekend! i can post no problem or cash on colection paypal or bank transfer accepted, i am based in west wales, pictures of everything will be added asap braking complete car so every thing is available, am open to sensible offers thanks for reading rossi
Old Oct 30, 2012 | 09:13 PM
3dr cossie's Avatar
3dr cossie
Interested in the rear bumper with the cut out, do you have any pics and can you post?
Cheers Matthew
Old Oct 30, 2012 | 09:22 PM
rossimk2's Avatar
rossimk2
Hi yes i can post no probs pics will be up tomorrow with a bit of luck
Old Oct 30, 2012 | 09:29 PM
Danielbetty's Avatar
Danielbetty
I will have bajoo springs mate pm me payment details
Old Oct 30, 2012 | 10:15 PM
peteh's Avatar
peteh
black samcos and header tank for me please!!
Ill defo have um, but pics of what I'm getting would be great please, hoses esp.
Also the diff mount, where did you get it from? R+B?
Old Oct 31, 2012 | 05:59 AM
RS SHAUN's Avatar
RS SHAUN
Intrested in the injectors pal
Old Oct 31, 2012 | 10:18 AM
RS SHAUN's Avatar
RS SHAUN
Is the MSD chip for L6 or L8 mate?
Cheers shaun
Old Oct 31, 2012 | 04:40 PM
Alex M-Sport's Avatar
Alex M-Sport
Hello,
I will have the new fan loom £30.
Regards.
Old Oct 31, 2012 | 04:58 PM
samashbymk2's Avatar
samashbymk2
I will have the siemens black injectors please mate - pm sent also on turbosport
Old Oct 31, 2012 | 10:35 PM
griffo69's Avatar
griffo69
Any pics of the autometer gauges
Old Oct 31, 2012 | 11:27 PM
Rs(555)'s Avatar
Rs(555)
Trim pics please !!
I am in Nantwich Cheshire mate , where abouts are you ??
Old Nov 1, 2012 | 07:58 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Can i have a pic of the standard 4x4 header tank please, if its in good condition i will have it
Steve
Old Nov 1, 2012 | 12:08 PM
wes's Avatar
wes
"as new clear indicators £15" - pics please
If these are genuine Ford items I'll have them
Old Nov 1, 2012 | 06:19 PM
fezzajsy's Avatar
fezzajsy
Pics of oil cooler pliz..
Old Nov 4, 2012 | 08:49 AM
samashbymk2
Any news on these parts mate???
Old Nov 4, 2012 | 12:10 PM
Mr C's Avatar
Mr C
Interested in the 55lb injectors if the sale fall through thankyou
Old Nov 4, 2012 | 07:36 PM
3drzetec's Avatar
3drzetec
where in wales are you matey?
Old Nov 5, 2012 | 07:00 PM
firthy's Avatar
firthy
pmed mate
Old Nov 7, 2012 | 02:46 PM
RS SHAUN's Avatar
RS SHAUN
Is this still breaking?
Old Nov 7, 2012 | 02:56 PM
peteh's Avatar
peteh
interested to know also...
Old Nov 8, 2012 | 07:36 AM
turblower's Avatar
turblower
Take 350 for wasted spark?
Old Nov 13, 2012 | 09:11 PM
AndyP87's Avatar
AndyP87
Hi. Don't suppose you have a cosworth down pipe?
Old Nov 15, 2012 | 07:56 PM
AndyPen's Avatar
AndyPen
Sorry to hear this mate - you can't be too far away from Swansea can you?
new genuine amber side repeaters @£30 - float my boat.
Old Nov 22, 2012 | 04:25 PM
M16NTE's Avatar
M16NTE
still got the loom mate? is it 2wd?
thanks gary
Old Dec 16, 2012 | 10:20 AM
danny_boy699's Avatar
danny_boy699
chatter 4 life
how much posted mate inbox me
Old Aug 3, 2013 | 04:05 PM
josenovo's Avatar
josenovo
Hi,
I´m interested with the sierra cosworth bonnet with vents. It´s available?
Cheers,
José Novo
Old Aug 4, 2013 | 08:41 AM
clyde 1800's Avatar
clyde 1800
Picture of the escort cosworth wheels please? I'm in Northern Ireland could you post and pm me a price please mate
Old Aug 4, 2013 | 08:49 AM
AJC's Avatar
AJC
Interested in the T34.48 if you'll sell separate
Old Aug 6, 2013 | 05:47 PM
bailey1's Avatar
bailey1
Hi do you still have rear bumper and tailgate ?? If so any chance of a few pics ?? Also don't have any front amber indicators do you ?? Cheers
Old Aug 6, 2013 | 10:37 PM
rossimk2's Avatar
rossimk2
Hi fellas, I had a good offer on the car and what was left last November 2012 all pms at the time where replied to, I did ask a mod to delete the thread , but was never done , sorry if this has caused any inconvenience regards rossi
Old Aug 8, 2013 | 08:02 AM
mavi3d's Avatar
mavi3d
Hi mate,
I'm interested in your gearbox. How many miles has it done?
Cheers,
Jon
SmudgerByName
52
Jul 28, 2016 06:14 PM
3dr cossie
11
Dec 21, 2015 03:38 PM
Ben26
Sep 1, 2015 06:29 AM
lukeeboy149
Aug 22, 2015 04:29 PM
yawiejon
Aug 10, 2015 08:12 PM
