Focus RS MIL Light fitting a Decat
Hi all,
I recently bought a Focus RS MK1 2002 with a performance manifold and exhaust running the original Cat. I have just put a decat on which has turned the car into a bit of an animal. I was advised that the car was set up using a Bluefin Map but the MIL light has come on on my way home this evening so I'm assuming it's because of the Decat. I will be putting the error code reader on later on but thought I'd get peoples opinion on here aswell. If it turns out to be on due to the Decat, can I turn this this off without having to get the car remapped as I believe the car has already gone down this route? Will the light being on have any effect on the running of the car i.e limp home mode etc. I will say the car seems to be spot on at the moment running wise, boosting and holding fine.
Any help or comments would be appreciated.
Dave
Dave
Same as on my MK2 ST225, I am going to make an o2 cheater using resistor and capacitor, you can get instructions online for it. Just plugs in between second o2 sensor and loom. Alternatively you can get lambda extension from here http://kalmar-union.com/parts/ford-focus-exhausts/ moves the sensor away from the flow of exhaust gasses so adjusts what it is reading.
track.focus'd
Aug 12, 2015 05:53 PM
