Sapphire DOHC 16v conversion
Old Apr 25, 2004 | 03:15 PM
Default Sapphire DOHC 16v conversion
I have seen posts on various sites about a 16v conversion for the 8v DOHC Sapphire.
Does anybody know if there is a kit, or parts available? Comparing the two heads (donor off an RS2000), I will need to modify the inlet and exhaust manifolds, and use the Sapphire rocker cover because of the 'distributor' (where is this fitted on the RS2000?), also the thermostat will need an adaptor pipe to move it from behind the engine in the saph to a more accessable position (I don't want to replace the head if the thermostat fails!)
Any info appreciated
PRD
Old Apr 25, 2004 | 04:07 PM
I think the people cahnge the whole engine. A friend of me fit the the 2.3l 16v engnine from scorpio/granda into his sierra.
the rs2000 use a distributerless system i think with a crankpostion sensor
hope this help
mk3ste
Oct 17, 2021 10:09 AM
Nov 1, 2015 06:53 PM
Rsmat
89
Oct 12, 2015 07:50 AM
Fil
Sep 30, 2015 12:08 PM
SMILER258
Sep 28, 2015 09:04 AM
