Ford Puma Discuss the Ford Puma here!
wet drivers side footwell :(
Old Oct 27, 2012 | 09:55 PM
baxter's Avatar
baxter
newbieeeee
Default wet drivers side footwell :(
on a r reg puma, when it rains now the driver side footwell is soaking..
any help or advice would be great, thanks.
Old Oct 27, 2012 | 11:48 PM
RichieST's Avatar
RichieST
Is the windscreen scuttle panel fixed tightly against the screen?
Old Nov 3, 2012 | 03:29 PM
melinamotor's Avatar
melinamotor
Farpylee
Heater matrix?
Old Nov 3, 2012 | 04:55 PM
Thrush's Avatar
Thrush
Irritating c........
Doesn't matter - it's not watertight anyway.
As said, heater matrix may be the issue - check to see if the cars water needs topping up; dead giveaway to leaking matrix.
Also, check the drain holes under the scuttle - if these get blocked the water backs up and finds another drain point; usually into the car through the bulkhead. Just had EXACTLY the same thing happen with a Galaxy screen we replaced - after three new screens it was still doing it, so I took the scuttle off, pointed a hose at it, and watched the water back up out the drain points, and find a gap in the bulkhead to flow through - leaving a swimming pool in the passenger footwell.
gcfcos
59
Oct 6, 2015 05:04 PM
Fudgey
21
Sep 30, 2015 06:19 PM
Shaunc
Escort Range
Sep 22, 2015 06:38 PM
