1990 Sierra cosworth 4x4 moonstone
For sale is my 1990 Sierra cosworth 4x4. The car is for sale due to family commitments. I have owned the car for 8 years and during my ownership the car has had a full engine reabuild and full respray. The car has only 3 former keepers (which is low for a cosworth) and only run for app 6 months of the year.
The car has wanted for nothing and has a folder full of receipts with most things documented (everything during my ownership).
Engine
Fully rebuilt engine by Andy Fisher (ex ford motorsport technician)
200 block (decked), standard head bolts
Block wire rung and dowled
Grp A headgasket
8:1 compression ratio
NMS stage 1 low lag head
0.5 oversized mahle pocketed pistons
fully lightened and balanced bottom end
ARP big end bolts
Brand new throttle housing with new tps sensor and brand new iscv
High pressure oil pump
Block oil feed modified
2wd sump gasket (no leaky 4wd gasket)
Grp A cambelt and tensioner
Turbo technics t34 55 housing
ARP flywheel bolts
2wd turbo oil feed (better oil supply to the turbo)
Grp A coil
Grp A fuel pump fully rewired (bosch 044)
Full mongoose 4inch exhaust (middle box removed)
Pro alloy rs500 intercooler
Airtec turbo cooler
Pro alloy breather kit
Full Roose silicone hoses in black
Vibra technics engine mounts
Grp A cone filter (GGR)
New starter motor
New alternator
Live mapped by NMS on greys
Power estimated at a genuine 370-380bhp
Transmission
Fully rebuilt gearbox
Standard diffs
Alcon 6 paddle clutch with heavy duty cover (new clutch cable)
xr 4x4 dirve shafts front
Suspension
Koni top adjustables
Castle performance front strut bace
Brakes
Ap racing 4 pots with 330mm disks
New rear calipers
Exterior
Headlight covers (genuine ford)
Rs500 front splitter
Wheels
17" 8j TSW imola alloys x5
215 40 17 Yokohama Parada (good tread)
Interior
Standard full leather in good condition
Slight shrinkage on door cards (common but not real bad)
Rs 4 spoke wheel (good condition)
Nomad boost gauge mounted in pillar pod
Dvd/cd player
Security
Clifford concept 300 alarm with certificate
This is a very reluctant sale and new owner will not be disappointed.
The car is a very clean example but is not concourse remember it is 22 years old.
The car currently has mot until august 2013 and is sorn.
Im not wanting any part exchange on this car, no test pilots and no texts or witheld numbers.
Serious buyers only.
Contact 07951 508590
£5400 firm
Engine
Grp A headgasket
ARP big end bolts
ARP flywheel bolts
Grp A coil
Airtec turbo cooler
New starter motor
New alternator
Transmission
Standard diffs
Suspension
Brakes
New rear calipers
Exterior
Wheels
Interior
Dvd/cd player
Security
£5400 firm
Hiya bud never had any arches! on the drivers side just above the arch there is a tiny bit of surface rust not much (me being critical) hardly noticable and nothing to worry about, around 4 years ago had a little plate welded on the chasis leg by the rear spring this was done by a mot tester with 30 + years of welding experience and never affects the mot as its structualy solid underneath for a 22 year old car, it has to be seen and heard in the flesh am based in the midilands bud
Deffo this car is beaut ads spent loads on this car i known this car for yrs whoever buys this is gettin an awsome saff no expense spared and meticously looked after glwts adam.
The first viewer came today and left a deposit so the car is now provisionally sold pending collection.
I just want to say thanks for all the kind comments and interest i have had in the car.
Anutternutter
Aug 21, 2015 06:07 PM
charliecosworth
Aug 19, 2015 02:00 PM
155lee
Aug 14, 2015 11:21 AM
