sierra 3 door replica, 4 pots do not fit !?
Old Oct 22, 2012 | 05:44 PM
kieranpat77's Avatar
kieranpat77
Default sierra 3 door replica, 4 pots do not fit !?
Hi, i have just purchased a sierra 3door replica, it had a big brake conversion done on the front, not very well either! I want 15inch rims so decided to put 2wd discs and 4 pots on. I fitted the 283 disc but the 4 pot does not fit, i was told the hubs are 2wd from previous owner. The hubs do have 12mm threaded holes and abs reluctors inside! I dont understand why they wont fit! About 4mm or so. Any light shed on this would be much appreciated.
Sorry for the drawn out explanation! thanks.
Old Oct 22, 2012 | 05:50 PM
james kiely's Avatar
james kiely
kieran 2wd discs are 278mm not 283,they are 4x4 cos
Old Oct 22, 2012 | 08:02 PM
martysmartie's Avatar
martysmartie
Wrong, OP is correct 2WD are 283MM, 4x4 are 278MM!
Are the hubs 2WD Cosworth hubs?
Martin
Old Oct 22, 2012 | 08:08 PM
kieranpat77
They guy i bought it off said they are 2wd cosworth hubs.
Old Oct 22, 2012 | 08:17 PM
martysmartie
Then there is no reason for them not to fit, what is the actual problem?
Martin
Old Oct 22, 2012 | 08:26 PM
kieranpat77
With disc on, when i offer the caliper in, it just about goes over the hub mount but then goes at an angle,, like either bracket is too thick. Im starting to think they are not cosworth hubs, perhaps standard. Although they do have 12mm holes, which i have read are cosworth...
Old Oct 22, 2012 | 08:44 PM
james kiely
quick edit required lol
Vincereese
Aug 15, 2015 06:24 PM
mpilk
Aug 12, 2015 09:40 PM
Vincereese
Aug 12, 2015 01:55 PM
Vincereese
Aug 11, 2015 08:44 AM
Old ford
Jul 31, 2015 06:50 AM
