Fiesta's Other ! This section is for ALL types of Fiesta models that are (NON RS / ST) Such as ZETEC S /S16000 / METAL /TITANIUM / GHIA etc
mk 5 fiesta zetec-s zvh turbo conversion
Old Oct 20, 2012 | 08:16 PM
big_will1985's Avatar
big_will1985
Default mk 5 fiesta zetec-s zvh turbo conversion
hi all, im currently mid fitting a zvh turbo into a mk 5 fiesta zetec-s and before i go any further i want to get the wiring sorted out. ive heard through the grape vine it doesnt take much modification of wiring looms but also heard that, although the ecu connectors are the same, a couple of the pins are in different locations. please can anyone help me out??
Old Jan 11, 2013 | 06:18 AM
Straight_4_N/a's Avatar
Straight_4_N/a
Well first off which engine bay you using? secondly why not bin the junk cvh head and fit the zetec-e 16v head with a de-comp plate? (doing a zvh turbo conversion is only for those who all ready have the cvh fitted if your going to fit a zetec-e/r into a diffrent car you should fit the whole unit)
Old Jan 11, 2013 | 02:38 PM
minder's Avatar
minder
WTF i think he will be using the engine bay that came with the car unless fords have started to make ones which you can change DON'T THINK SO DO YOU ??
Old Jan 11, 2013 | 03:35 PM
Straight_4_N/a
i think you misunderstod what i ment.
zvh is a mix of two engines a cvh top end and a zetec-e II bottom end.
zvh is only normal done to engines that are already running cvh engines to upgrade them quickly but since hes putting the engine into a total diffrent engine bay he mite as well go for the full zetec-e II engine to make the most of the power.
(hes fitting it into a fiesta 2000 shell where it needs some work to make it fit so he mite as well go the full wack and have a 16v head on the engine rather than the 8v head)
Old Apr 28, 2013 | 11:26 AM
Standarduk's Avatar
Standarduk
Default re: zvh in mk5 fiesta
HI,
He is actually fitting this into my fiesta. The reason why we are fitting a zvh is bceuase its one that been built by grove garage and has about 360bhp. The CVH head has had lots of work done on it.
So the question remains re: the wiring as it has now been completely fitted bar that. (Gearbox from courier van, custom driveshaft and engine mounts, power steering removed...etc)
The wiring we have is the engine loom from RS turbo that the ZVH was originally in. I have read somewhere that you dont need to remove r touch any of the zetec loom just splice in bits of the ZVH loom from the RS. But just dont know where to start
Matt Baxter
Sep 16, 2015 08:30 PM
Ben26
Aug 27, 2015 08:56 PM
paceo
Aug 27, 2015 12:45 PM
turbobill
Aug 1, 2015 08:55 PM
