hydraulic clutch reyland kit
hi anyone using one of these kits?? , advice on set up do you need to adjust rod length as it seems to push quite a bit of pressure on clutch, i.e when in stationary position pushes hard on arm no freeplay etc
any advice guys or martin if your on here cheers
pedal height is fine but the rod has i think to much load on the arm no free play at clutch arm on the gearbox, just checking as seen others spaced out etc , seems to much static load to me
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
