oil cooler
fitting an oil cooler to the cossie and i wanting to know rougly how much extra oil do i ad to engine to compensate for the oil in the rad and pipes.sandwhich plate fitted with theromstat that opens at 80c or i have a normal one,which is best?
cheers mark
cheers mark
in theory you can calculate it. The cooler manufacturer should be able to tell you oil volume of the cooler, and you can calculate the volume of your pipework dead easy.
however in practice its not much and probably no more than half a litre even with a bigish cooler and pipe run.
If its a road car then you MUST have a stat in the take off plate otherwise on road driving you will very rarely warm the oil up sufficiently.
