Timing Belt Came Off, Please Help...
Old Oct 18, 2012 | 08:30 PM
surrey_100e's Avatar
surrey_100e
Default Timing Belt Came Off, Please Help...
Okay so, when i first got my engine i accidentally broke the tensioner pulley resulting in the timing belt coming off. Im pretty sure nothing moved but i want to be sure before i turn the engine over.
Is there anyway i can align it so the cams and crank are where they are suppose to be, would a mobile mechanic be able to do this, or maybe even take the car to ford or volvo? Its a focus st225 engine (volvo t5).
Any help much appreciated.
Old Oct 18, 2012 | 08:55 PM
COCHYN's Avatar
COCHYN
How did you brake the pulley and was the engine running at the time? Which pulley is it?
Old Oct 18, 2012 | 09:07 PM
surrey_100e
I actually have no idea
No the engine was on the bench in the garage at the time.
It was the self tensioning one that has a spring in it to tension it, ive since replaced the pulley with a new one, but just need to make sure everything is in alignment before i put the belt on.
Old Oct 18, 2012 | 10:48 PM
Rossy43's Avatar
Rossy43
Fiesta ZS. FF feat nov'11
Turn it over by hand?
Timing light?
Old Oct 18, 2012 | 11:02 PM
AstoN_B's Avatar
AstoN_B
An eye for detail...
Look for timing marks? And stop messing with important shit! Lol
Old Oct 18, 2012 | 11:16 PM
botters's Avatar
botters
competant bodger
piece of piss
Old Oct 19, 2012 | 07:23 AM
rs graham's Avatar
rs graham
From: In the pub cheering on Ricky hatton and Joe calzaghe
Just line the timing marks up as on picture. A timing light is for ignition timing NOT cam timing.
Old Oct 19, 2012 | 01:13 PM
CosworthGuy's Avatar
CosworthGuy
3dr Cosworth owner
As said. Time ut up correct and turn by hand. If summats fucked then its already fucked isnt it. You'll soon know if there is piston to valve contact when you turn it over by hand
Old Oct 19, 2012 | 05:45 PM
CHUNKYS RS's Avatar
CHUNKYS RS
not to sure on the focus engine but when i worked a volvo which this engine is based on when aligning the cam marks be carefull if they have vvc units on as you need to make the units are under tention i.e turn the cams back half a turn then forward to the timing marks ,if that maks sence
RUBY123
Oct 22, 2023 12:04 PM
xrmalin
Sep 13, 2015 06:52 PM
hopper350
Sep 4, 2015 12:53 AM
YODI
Aug 30, 2015 01:12 PM
cameron2
Aug 25, 2015 07:18 AM
