Ford Range This section is for other models in the Ford range.
ESCORT VAN MK6 diesel pump help
Old Oct 17, 2012 | 12:37 AM
PETEDUDE007's Avatar
PETEDUDE007
Default ESCORT VAN MK6 diesel pump help
ok in brief
i bought a van 1.8d non turbo with suspected faulty diesel pemp fault.
the reason we suspect it is faulty is due to the fact it is secondhand and was swapped over to replace the original item which was running perfectly and leaking
so i have swapped it back to the original leaky item and now cant get it to start.
i can pump fuel through by hand and ive also tried starting the van whilts using a different source for fuel as oppose to the tank i used a jerry can.
anyway i cant get it to start i cant seem to get fuel to the injectors.
can someone post up some pics so i can see if i have it plumbed right as it wasnt me that took it apart and im not a mechanic im just guessing and making it up as i go.
i have had a ouple of friends look at this but by the time they got to look at it it was too late and i fear ive done something wrong.
hope this makes sense cheers
Vincereese
Jun 1, 2023 09:14 AM
FlashRS
Sep 14, 2015 12:36 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
druidgetafix
Aug 15, 2015 10:22 AM
