Focus 2006 rear numberplate lights
Hi guys,
My 2006 Focus has an issue with the rear number plate lights not working. I have checked the bulbs and they look OK so I guess the next stop is checking the fuse. However, the fuse board is different to the diagram in the owners manual so I am unsure which fuse to check. The actual fuse board has 3 rows (2 x 22 fuses and one row of 6). Has anyone got the correct fuse number (and rating) that needs checking?
Cheers in advance,
Alan.
Cheers in advance,
Alan.
[QUOTE=sykes2009;6083019]according to hand book it should be number 73 and 7.5 amps
on the bottom row this is right had same problem with mine ford garage said the fuse was not a separate one was same as side lights .Not correct
Number 73 bottom row and is a 7.5 amp fuse .saw this thread and much appreciated
