Rev counter wiring and problem if efi cvh turbo Orion
Hi. I had fitted a Astra get Digi dash to my Orion a year back and the rev counter has always been working but on a low reading ie approx 4000 revs shows about 2000
Anyway I bought a universal rev counter pod type and wired it up to green wire hoping this would be accurate but it's the same as the Digi dash one
My question is could I run a new feed for the rev counter ie from alternator etc as I think the green wire currently goes to the edis module for pickup but maybe this isn't a clean enough signal for non efi rev counters
Ok can someone just finally clarify this for me do I take a new green wire from the unused pin on the edit straight to the clocks and just cut and tape back the old one so the engine will still run well ?
JoeyBoyden
Aug 18, 2015 05:56 PM
ekjim
Aug 17, 2015 08:57 PM
cozzy jeff
Aug 14, 2015 05:46 PM
