6 degree rear beam for 2wd saff
Need a 6 degree beam soon for my saff but don't know much about them! Which ones the best? What sort of prices? I read some where that u can just have your standard beam converted? Thanks in advance!
i asked the same question a year or so back
here's my thread
https://passionford.com/forum/genera...fo-needed.html
i ended up with a turbosystems 6degree beam
here's my thread
here's my thread
here's my thread
I was on a similar thread and was advised to stay away from them.
Just saying like...I'm trying to find the thread somewhere... Nobody from TS came on to abject or defend what was being said so thought that's one t stay clear of.
Im in the market for a 6degree rear beam too- if we decide on a maker-could try and get a group buy on the go??
5 beams bound to get a discount from a trader... hint hint
Sorry but I think you are wrong mate, you never got yours set up properly iirc, you have to get it done on a proper four wheel laser bed, or it will never be right. My stage two adrenaline beam is perfect.
Any of the beams mentioned will do the job well, too many Internet stories floating about, you would never buy anything if you listened to them all
I'm not alone then. I'm going from what I have experienced. Too many times I have wrote down what the faults where.
It was removed and an SCS one fitted and the difference was night & day.
Chris, one thing I always remember, swapping from 2nd to 3rd lane on the M6 at 70ish. Quite quickly, it felt like the car was going to spin and land in the central reservation.
I promptly took it home and parked it up and didn't use it for nearly a year
Or they should have been able to bang them out all the same.
That's a bit contradicting mate ^^^.... If it's badly set up either by the supplier or Jesus then it's a lot to do with badly set up wouldn't you think.
Sorry, what i ment was that the set up is nothing to do with the beam manufacturer. ie it wont come back from -said beam supplier- ready to fit and drive.
Nah it's ok mate... What I meant was if its not a true 6 degrees to start with like Jay says then its badly set from day one... But I know what your saying mate.
Glad I didn't buy one a few months back now that I was offered!
What happened to adrenaline? Did they shut down or still about? May be worth contacting them.
