flywheel dimensions?
Old Oct 12, 2012 | 04:50 PM
AiToR51's Avatar
AiToR51
Default flywheel dimensions?
Hi,
I want to install a focus I RS AP Racing clutch on my sierra turbo. I've in house an escort MK5 RS2000 flywheel which is supposed to match a focus RS clutch and my engine.
But I prefer to check myself the correct measures, as is not flat surface, to know if I've to remachine my flywheel and in that case I want to know the correct numbers i've to tell to the remachiner.
In my case, from the disc surface to the cover mount I've around 8.5mm
I've readed that the distance between bolts are the same, but if anybody can measure it could be perfect.
Regards!
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Mark_
14
Jan 16, 2016 05:27 PM
Jman-pat
Ford Focus Diesel
Nov 8, 2015 01:29 PM
IainRS1700T
Sep 25, 2015 06:44 AM
DPDISXR4Ti
Ford Fiesta
Sep 21, 2015 03:51 PM
