Ford Focus RS Front Suspension Arms / Wobble Problem
Old Oct 11, 2012 | 06:20 PM
davidnormanuk's Avatar
davidnormanuk
Default Ford Focus RS Front Suspension Arms / Wobble Problem
Hi all,
Does anyone know if the bottom arms on a Focus RS are the same as the standard focus. Basically I have a wobble, and the car is pulling the the right so i'm going to start there.
The car has been to the garage, been tracked and wheels balanced which hasn't improved anything so the next step is to start replacing known wearing parts. I had this kind of issue on and Escort Cosworth a few years ago and it turned out that the hub was warped so I will be sticking a gauge on the this weekend to find the wobble problem.
Any other suggestions would be appreciated
Old Oct 17, 2012 | 06:24 PM
lowman's Avatar
lowman
maybe you should tell us more about the car...what kind of focus rs it is....mk1...mk2...
buut...i dont think the lower arms are the same as on the standard focus...cause it got wider track...and i guess that its the lower arms that makes the wider track..
but i dont know..
track.focus'd
Aug 12, 2015 05:53 PM
taylora1409
Aug 12, 2015 12:06 PM
Old ford
Jul 31, 2015 06:50 AM
