WHERE CAN I ?
I need to remove my Turbo from the manifold because its got a small blow in it where the turbo joins to the manifold and was wondering will i need to remove the radiator so i can remove the turbo because its very tight getting to the bolts and also bending up the tab washers. Once ive removed it il then need to replace the tab washers and was wondering where can i buy new ones from any advice would be gratful
Just one other thing is there a gasket you can buy thats goes in between the turbo and manifold?
the gasket is a metal one, i managed to take my turbo of with radiator
in and engine in, i took it of with the manifold on so might be easier to take it
of and leave manifold on engine.
