Storing my car outside for winter, underside q?
Old Oct 10, 2012 | 12:12 PM
2wdsaph ben's Avatar
2wdsaph ben
Default Storing my car outside for winter, underside q?
I've got a xr4i which I've sorned for winter. It's likely it will be sat about until spring.
What can I do to it to protect it. I've bought a fully waterproof breathable car cover, dehumidifier pots for interior but its underneath I'm not sure about
It has been stone chipped by previous owner. Should I spray something over it like wd40 or wax oil
Cheers ben
Also anything I ca do to protect engine bay?
Old Oct 11, 2012 | 12:23 AM
STAFFY OWNER's Avatar
STAFFY OWNER
Car looks tidy underneath. I would have thought that if you leave it on a hard standing like a concrete or tarmac driveway it should be ok (rather than damp grass). I've heard of people putting a few old blankets in the engine bay in the past but make sure you remember to remove them if you start it up periodically.
Old Oct 11, 2012 | 06:22 AM
AJC's Avatar
AJC
On hard standing is best. No grass!
Old Oct 11, 2012 | 07:38 AM
Mr S1's Avatar
Mr S1
Don't ask - I don't know
Hard standing and make sure the air can get under the car. Don't tuck the cover to the floor thinking that's good as it isn't - you need to let the air get around it as much as possible.
Old Oct 11, 2012 | 08:59 AM
Brendan's Avatar
Brendan
struggling with reality
see if you can get a second hand carcoon the out side version! they have little fan to keep the air flowing and the car dry. failing that you might want to knock up a set of fans to help keep the air moving under your car. If I were to do this I would think about some 12v ones scavenged from old PC power supplies! you could power them from the battery and leave it on charge so it doesn't go flat!
Old Oct 11, 2012 | 09:03 AM
2wdsaph ben
Thanks for replies, it will be on a hard standing. Do you know the reason for blankets as never heard of that before. Would it be good idea to cover engine bay in silicone spray?
original
Apr 28, 2026 05:20 PM
Rob_DOHC
Computers, Consoles and I.T.
Aug 15, 2015 11:17 AM
TIL13R
11
Aug 13, 2015 02:28 PM
