Tdci alternator/auxiliary belt
I need to do this as its getting a bit noisey when started from cold. Also signs of perishing. What else should I do at the same time and is it a bitch to do?
You can do the bottom pulley while you're at it. But they can be very hard to get off without a windy gun.
You'll also either need to get one of or fabricate your own device to release the tension. Even with the tool it can be hard to get the belt back on. It's easiest to have one person on the tool, and one prising the belt back on.
Also, note very carefully how the belt goes, as you have to take one of the brackets that the belt feeds behind, and it's a ball ache if (like me) you refit the bracket, before running the belt correctly.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
The Enigma
Sep 29, 2015 10:31 AM
