Ford focus 2.0l project
Moondust silver ford focus.
This was a project that I started 3yrs ago it is a 4door 2.0ghia.
The engine has been fully rebuilt.
Engine spec.
Head has been skimmed 2 tho of a mil
New valves.
Oil seal
Piper springs
Piper fast road cams and pulleys
Shims been shimmed for correct clearance
New piston ring that came from germany
New bearings main and big end
Arp rod bolts and main bolts and cam bolts. Also have head bolts but didn't use
New timing belt and aux belt
Crank has been balanced with pistons and lightened flywheel
New clutch and slave
Gearbox been rebuilt with new oil
New oil pump
New water pump
Every gasket and seal is new
St170 manifold with custom decat
St170 air box and snorkel with k and n panel
Full stainless exhaust
Front engine brace fitted also
Has short shifter fitted doctors sport dials
A few carbon wrapped parts interior wise
All sound proofing has been removed and carpets back in
Engine starts first time all it need to fixing is cams dialled in and remapping
It would be a good engine in a kit car.
Can be heard and seen running!
The car is by no means show condition body wise. Most interior is stripped but will come with the car. It has coilovers on there dirty but fully work.
I am selling this car and part I have now as cant afford to finish it so its sitting collecting dirt. I have a 19month old son and hoping to get married in sept so need sell what I have
Looking for £1800 ono
Any questions please ask
Engine spec.
New valves.
Oil seal
Piper springs
New oil pump
New water pump
Thanks
http://i169.photobucket.com/albums/u...d/IMG_2070.jpg
http://i169.photobucket.com/albums/u...708_214701.jpg
http://i169.photobucket.com/albums/u...60708_2028.jpg
http://i169.photobucket.com/albums/u...708_214702.jpg
http://i169.photobucket.com/albums/u...psc17e1bba.jpg
