1999 306 GTi-6 OEM+ for sale
Old Sep 26, 2012 | 07:56 AM
Matt Evans's Avatar
Matt Evans
Black Country RSOC
Default 1999 306 GTi-6 OEM+ for sale
1999 Peugeot 306 GTi-6
I’ll try and give as many details as I can on the various sections of the car to give you as much insight into whats been done in the 3 years I’ve owned it.
Engine – standard xu10j4rs GTi engine, rebuilt over last winter with new bearings throughout, new oil seals, genuine Pug headgasket & Bolts, new cambelt kit & water pump, clutch and release bearing. The engine assembly itself was subjected to a thorough detaling with zinc plated bolts and fixings, powdercoated engine brackets and new Peugeot engine and gearbox mounts. Has done only 500 miles since being refitted in the car and is still being run in. It has a Lynx solid alloy bottom pulley and has the rallye aux belt tensioners and new gen pug aux belt also. Radiator is a Nissens alloy rad, which has done less than 4000 miles on the car. New gen pug bottom and top hoses and clips. A/c removed, both gti twin fans present and working correctly. K & N 57i induction kit – with correct inner wing support bracket also. Gearbox was detailed and fitted with new clutch arm bushes and drain plug. New gen pug driveshaft oil seals and pug gear oil used when refitted. Clutch cable replaced with new pug one at same time. Clutch is light and progressive as they should be. Genuine Pug battery fitted less than 6 months ago.
Suspension – Front.
Bilstein B8 Dampers fitted with Eibach 30mm lowering springs, new top mounts and bearings fitted, along with drop links and new wishbones with QH ball joints and P-Bushes. Xsara VTS Phase 1 (2.4 turns) steering rack with new boots and track rod ends, with GTi-6 steering ram swapped over. Fully detailed subframe and anti roll bar, all powder coated and painted. New Anti roll bar bushes and hub pinch bolts.
Rear – Fully rebuilt rear beam with full kit of gen pug bearings and seals used throughout, fitted with Xsara VTS 21mm torsion bars and lowered 20mm. Bilstein B6 rear dampers and new beam mounts fitted, along with the beam being detailed and restored to better than new condition. New anti-roll bar end plates and seals. Beam is as new, so no knocks, creaks etc etc.
Brakes – Front
Brembo 406 v6 4pot calipers, freshly fitted and refurbed with new seals, powdercoated red with new bleed nipples and new Pug 406 v6 pads. Tarox 44 groove Xantia V6 discs with the correct 288mm diameter. NO squealing on this kit. New braided brake lines and fresh fluid.
Rear – Tarox 44 groove gti-6 discs with powdercoated yokes, and new brake flexi’s and genuine pug hard line brake pipes from caliper to under the car. New pug back plates and new pug pads. Calipers are both free and work 100% with an excellent handbrake also.
Wheels / Tyres – Compomotive VLM 1670 alloys, made especially for me for this car, ET15, 7x16” with 195/45/16 VR rated Yokohama S-Drive tyres all round, with 6mm tread on all tyres. Wheels are unmarked, never seen a curb and are as new.
Body – Standard bodywork, finished in Astor Grey Pearl metallic, is washed every week regardless with the two bucket method and washmitt, never seen a car wash, paintwork is immaculate with no swirls or noticeable scratches anywhere. Yellow fogs in the front bumper, custom front badge, standard rears. Has a HID kit fitted – a sensible lowish power one, still has correct beam pattern and passed 2 mot’s with them in.
Interior - Standard GTi-6 leather/alcantara trim, GTi-6 tailored floor mats and boot mat, in immaculate condition throughout. Standard Clarion stereo with boot mounted 6 disc cd changer and steering column stalk – all working. Has got a snap off steering wheel (suede) with correct Momo air-bag boss kit. Has a rallye top glovebox fitted also for extra storage. New Gen pug leather gearknob fitted. All electrics work fine, door looms are fine, windows and remote deadlocking work spot on. Two keys and key code / security card from new.
Other – has undergone substantial improvement and restoration over the last 2 years, with the engine bay and brakes being done very recently. There has been so much done to the car its impossible to list in one sitting, id advise a thorough read of my project thread to get the full idea of what works been done.
Mileage – car is showing 105k miles, suspension has done less than a 1500 miles, engine about 500 miles and the brakes less than 200 miles, so most of it is almost new.
Car has done about 3k miles since ive had it, and im the 4th owner.
MOT till June 2013, tax till end November 2012
History – Has all bills and MOT’s and service history from day one, and everything ive done is documented on here in intricate detail.
Car is HPI clear, and my private plate will come off when a deposit is taken.
Genuine reason for sale, it’s a little used third car in the Evans household, and I’m looking to replace it with something larger for the two kids in the back, hence an Octavia Vrs will be hunted out if and when the Pug goes.
Im looking for Ł3500 for the car or very near offers as I suspect its one of the cleanest 306 GTi-6’s ive seen for a while, and with all the modifications that people want, in the best colour!!!
Ive attached a link to my resto thread below.
http://www.306gti6.com/forum/showthread.php?id=125121
And some pics to highlight key points..
Old Sep 26, 2012 | 08:32 AM
gordyshreds's Avatar
gordyshreds
Love that! Super tidy and obviously very well cared for! Good luck with the sale, not that I think you'l need it
Old Sep 26, 2012 | 09:08 AM
bazzal's Avatar
bazzal
i'm not in a position to buy it but I must say that is stunning, credit to you, all the best with the sale.
Old Sep 26, 2012 | 10:23 AM
RSPSTEVE's Avatar
RSPSTEVE
Very nice .
Old Sep 26, 2012 | 10:45 AM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
That really is a nice car.
Old Sep 26, 2012 | 03:07 PM
RST's Avatar
RST
Proper nice car mate GLWS
Old Sep 26, 2012 | 03:57 PM
Maxwell's Avatar
Maxwell
Irregular Poster
beautiful 306 you have there mate!
Old Sep 26, 2012 | 06:00 PM
Matt Evans's Avatar
Matt Evans
Black Country RSOC
Cheers for the comments guys, the cars been an obsessive passion of mine for three years, and the quality of the modifications and fitting the best parts available mean its far in away above the usual 306.
A video i filmed some time back. Bear in mind the mic was secured to the induction kit, and the gopro camera was on the side of the car.
Old Sep 26, 2012 | 06:42 PM
adam151082's Avatar
adam151082
Sounds nice at high revs, you should let it get there a bit more.
Old Sep 26, 2012 | 06:53 PM
Csm's Avatar
Csm
Fuckin miss the fun of these, luv them.
Glwts fella
Old Sep 26, 2012 | 07:28 PM
jock05's Avatar
jock05
This car is so nice in the flesh it will make your balls tingle.
I still think you should keep it you nutter!
Old Sep 26, 2012 | 09:32 PM
Shings's Avatar
Shings
If I wanted one I would certainly be interested in this, as I don't if you get a bit desperate I might fancy a punt as I could buy it and put the Focus away for a bit.
306 GTI6 is one of only a hand full of cars I have owned and genuinely enjoyed - everyone should own a 306 in my opinion.
Old Sep 27, 2012 | 08:43 AM
bigryrs's Avatar
bigryrs
RSHoleinator
That is stunning mate! Credit to you and glwts
Old Sep 27, 2012 | 03:46 PM
Wow its like a concures car.
Old Sep 29, 2012 | 08:03 AM
Matt Evans's Avatar
Matt Evans
Black Country RSOC
Weekend bump!
Old Sep 30, 2012 | 08:42 AM
ROB7656's Avatar
ROB7656
Cracking car! Makes my china6 look a shed
Old Oct 3, 2012 | 07:33 AM
Matt Evans's Avatar
Matt Evans
Black Country RSOC
Close offers considered.
Thanks, Matt
Old Oct 3, 2012 | 07:47 AM
packman's Avatar
packman
Well done looks a well sorted car , dont normanly like pugs but the 306 GTI-6 does go round courners well as standard plus the engine is a peach , nice work.
Old Oct 6, 2012 | 10:21 AM
nealo's Avatar
nealo
Focus WRC
Absolutely lovely motor mate but a bit too rich for me at that price, glws tho its a cracker!
Old Oct 6, 2012 | 09:56 PM
Munch's Avatar
Munch
Mr. Sparkle!
Lovely 6 mate...Just needs some 'Bodies and that'll be perfect!
Old Oct 9, 2012 | 07:32 AM
Matt Evans's Avatar
Matt Evans
Black Country RSOC
Cars now sold....Thanks for the kind comments.
Old Oct 9, 2012 | 07:51 AM
mr west's Avatar
mr west
great cars, i loved my rallye. this looks mint too mate.
Old Oct 10, 2012 | 04:53 PM
siddleg's Avatar
siddleg
what a fantastic car would give you every penny if i was in the market
Old Oct 10, 2012 | 05:43 PM
WongRS's Avatar
WongRS
That was quick Matt, love that car
tankybaby66
Feb 6, 2016 02:24 PM
gcfcos
59
Oct 6, 2015 05:04 PM
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
Marv888
Sep 26, 2015 03:44 PM
