sold
have a rs turbo efi engine for sale . it is standard 1.6 bottom end only covered a few thousand miles since rebuilt . nick waples ported and polished cylinder fitted with bigger valves, double valve springs , piper t2 camshaft and vernier pulley . head has just been removed been skimmed and rebuilt with new seals and gaskets . all valves have been lapped in . has had genuine ford head gasket and a new timing belt and cam has been timed to spec using a dti gauge to get correct full lift . engine comes with alternator and crank sensor , inlet manifold with beige injectors . crossover pipe.camcover. t3 stage 2 turbo,turbo drain and feed tubes . but doesnt have exhaust manifold as had crack in it . has thermostat housing , 4 paddle ap clutch fitted. only covered 3k miles.coil pack and motorsport ht leads. engine and turbo good for 200 bhp with correct ecu and chip . any questiojns please just ask
£580 delivered uk
£500 collected
£580 delivered uk
£500 collected
155lee
Oct 24, 2015 11:11 AM
