Anyone got a Standard Sapphire Cosworth 4x4
I am looking for some info if anyone could help.
1. Sitting on standard Suspension how far is the bottom of the Front Crossmember off the ground ?
2. Sitting on standard Suspension what kind of angle are the TCA's at i.e. fairly level, dropping down to hub or rising up to hub ?
3. Roughly how high is it from the crossmember at the engine mounts to the top of the cam cover ?
Any info would be much appreciated.
Andrew
Andrew
lukeeboy149
Aug 22, 2015 04:29 PM
