Cosworth turbo pipes
Old Sep 14, 2012 | 02:33 PM
Ryoishikawa's Avatar
Ryoishikawa
Default Cosworth turbo pipes
Brought these Serria braided turbo coolant hoses. Don't need them now brand new items.
1 return pipe
1 feeding pipe
connectors to screw them in direct into the turbo
. £40 posted
Taken from seller on eBay
HI AND AS YOU ARE NOW LOOKING AT THIS ITEM YOU PROBABLY HAVE GOT THE SAME PROBLEM I HAD .....* WITH YOUR ORIGINAL FORD RIGID PIPES EITHER CRACKED OR BLOCKED AND YOU ARE ALSO NOW PANICKING IN CASE YOUR TURBO STARVES OF WATER WELL BUY THESE AND YOUR PROBLEM IS SOLVED .... WHAT I AM OFFERING IS A PAIR OF DIRECT REPLACEMENT STAINLESS STEEL HOSES WITH THE HEAT RESSISTANT PTFE LINER THESE HOSES DO FIT THE T3 T34 AND T38 SURE THEY WILL FIT OTHERS BUT NOT 100%.
s1cab
Jul 26, 2018 06:11 PM
big_Rad
Sep 15, 2017 09:36 AM
jaysoc1
Aug 21, 2015 05:38 PM
IAN RS2k
Aug 18, 2015 07:51 PM
Aug 14, 2015 07:29 AM
