st170 conversion help
Old Sep 7, 2012 | 11:36 PM
bakerboy18's Avatar
bakerboy18
Default st170 conversion help
Hello all,
Im in desperate need of some help i brought a mk1 focus st170 conversion registered as a 1.4 from ebay as spares and repair. the previous owner said it was headgasket and dash/dials not working (simple wire fix i was told) i replaced the gasket with timing belt along with the cams (both cracked.) fitted new battery and tried to start. unable to get it started i decide to remove the toad alarm. by doing this i managed to get it started i drove it around the block when it cut out on me. back to the drawing board i decided to tackle the dash problem as there are no lights except oil and hankbrake warning light. i remove the i dials and tried to start. the car fires up on the button. refit dials and still started first time then i noticed the oil pressure guage was still unplugged. when plugged in the car wont start but will every time when unplugged.now i suspect that the kid i brought it from didnt do a full st conversion and it still has the standard 1.4 dash loom thats why the dials and oil pressure guage dont work. please help as this car is a real beast and needs to be up and running.
any help will be great
mk3ste
Oct 17, 2021 10:09 AM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
SMILER258
Sep 28, 2015 09:04 AM
Sp3no
Sep 27, 2015 07:23 PM
Marv888
Sep 26, 2015 03:44 PM
