Help needed urgently, no spark
Old Sep 7, 2012 | 03:24 PM
ginner's Avatar
ginner
Default Help needed urgently, no spark
Does anyone fancy comming to newark to get my car started , basically it cranks , is getting fuel but no spark , u will be fed watered and paid for your time thanks
Old Sep 7, 2012 | 04:15 PM
DAN-Saff's Avatar
DAN-Saff
Are you getting power to the ecu?
Old Sep 7, 2012 | 04:17 PM
mothrs2k's Avatar
mothrs2k
Lmao what car is it?
Old Sep 7, 2012 | 04:45 PM
ginner's Avatar
ginner
What's so funny, it's a Saph 2wd
Old Sep 7, 2012 | 04:55 PM
Alvyn's Avatar
Alvyn
what was the car like before this happened ie was it running?? could be cps,ignition amp or phase sensor knackered!
Old Sep 7, 2012 | 04:56 PM
martysmartie's Avatar
martysmartie
Because it helps if people know what car it is
What have you done yourself so far?
The fact it has fuel shows the CPS to be working, so if you are able to check the coil has a live feed on the black wire WITH the ignition on, check king lead is securely connected, rotor arm and cap are good.
After that we are onto more advanced things such as looking at ignition amps etc.
Martin
Old Sep 7, 2012 | 05:01 PM
mothrs2k's Avatar
mothrs2k
Just the fact you wanted help, but didnt mention what car you wanted help with lol
Have you checked all the usual things? Leads, coil, ecu, dizzy, sensors?
Old Sep 7, 2012 | 06:36 PM
ginner's Avatar
ginner
Sorry edited double post
Old Sep 7, 2012 | 06:49 PM
ginner's Avatar
ginner
Sorry I was fucked off with it earlier, I'll go into more detail, I had my engine rebuilt and while It was out I bought a new Cw loom.now when I took the old loom out there was a wire that ran from the multi plug to the drivers side somewhere I'm assuming now its immobiliser related as now I have no spark, my problem is I'm not a mechanic or a auto elec, and I don't know which pin this wire goes to and I don't feel overly confident in trying,
So I will pay for someone to come a help me out
Old Sep 7, 2012 | 08:29 PM
James @ M Developments.'s Avatar
A full aftermarket engine loom is plug and play so unless you have cut into it to fit an Imobilizer there should be no reason for no spark really, unless a power feed to the loom has been cut.
Test for power to the coil and ecu as a starting point.
Escortdriver1
Aug 19, 2015 09:02 PM
cozzy jeff
Aug 14, 2015 05:46 PM
Zoggon
Aug 10, 2015 10:39 AM
col93saphcos
Aug 7, 2015 03:21 PM
adriansaleem
Aug 1, 2015 09:28 PM
