Mk3 Mondeo tdci
need the part number mate, as my car is being a bastard replaced everything the code reader has said and its still playing up, led to believe its the ecu so im going to get a matching one and try it to see if that fixes it.
injector's are the most common problem they went on my 2003 model
£250 each from ford
i paid £250 delivered off fleabay , bought a special tool to change them then got them set up at ford @ £92 for one hour on computer.
aint missed a beat since (touches wood)
mine used to drive great until it was under a little load ( got easier to get it to go into limp mode )
if i turned the ign off and then re started the car it would be fine for a while.
code reader said fuel pump or injector pressures so i went with the cheapest first
£250 each from ford
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Steve Escos
Oct 1, 2015 06:57 AM
The Enigma
Sep 29, 2015 10:31 AM
