C1165 ABS fault code
Old Sep 2, 2012 | 03:25 PM
RichieST's Avatar
RichieST
Default C1165 ABS fault code
Got the ABS light on on my shitter mondingo. I've plugged my scanner in and it's saying C1165 RR Speed Sensor Input Circuit Failure.
Does anyone know if this relates to the ABS sensor, wiring or back to the module?
Rich
Old Sep 3, 2012 | 08:46 PM
B19 JUB's Avatar
B19 JUB
check wiring from sensor to module.if all ok more than likely sensor fudged
Old Sep 3, 2012 | 08:48 PM
RichieST's Avatar
RichieST
I got a new sensor yesterday from Ebay, was only £15. I'll get it fitted and see what happens. Mechanic mate of mine says the screws the fix the sensor in can often be a pain to get out, so hope I don't snap the fooker off!
tankybaby66
Feb 6, 2016 02:24 PM
muzzman1
Sep 30, 2015 08:59 PM
