wot dif u running with YB in a atlas?
wondering wot kinda diff is needed, or people are running without issues in a YB converted car using an atlas axle... power is stage 3 so round 300bhp mark.
Not on the road yet but im using a 3.44 in my cortina, depends what your doing with the car my axle builder said the 3.75 is the one to go for as a good all rounder, im planning on doing a few road miles with mine so went with the 3.44.
I'm using a 3.75 final drive, Tran-X LSD and 18 Spline Tran-x Shafts. Also the the tubes are fully welded onto the pigs head.
Looking at around 500bhp to run through it, car is not up and running yet though so cant comment on how reliable it is.
yea iv spoke to cuple people and they said 3.75, are u using a lsd? wot make dif also?
What sort of things are you doing with the car.
Dont have an LSD as yet, i had my axle buit for the car and the axle i used had a 3.44 so just stuck with it, im using HD single pice shafts as orginaly is was going to stick to under 300 hp, now my engine spec is growing and im not sure how long the axle will last, when it gos i will go for two pice shafts and a LSD.
im just running standard ford shafts, lsd and 3.44 diff gives about 20 mph per 1000rpm in fifth. no problems so far but then again i only run 195/50 15 tyres. grip will have big effect on what yo need
On my mk1 escort i ran a 3.44 baby atlas with 2 part r.a.c.e shafts & standard capri lsd that gartrac converted to 18 spline & uprated plates. Running 330bhp no problems (on leaf springs) Got used at Santa pod & track days. No issues.
you can get an 8.8 mustang axle with lsd with ratio of your choice for around Ł900 from america they are used as an upgrade for 500bhp+ mustangs so will handle anything you can throw at them far better setup than a Ł5k atlas imo
Sits fine and clears very tight tho. and thats with 10mm extra track on front due to brakes and 20mm on rear for the same. Prob will have to go for 35 profile on front just to be safe. don't forget mines a mk3 so i have a little more room i guess.
does anyone think a capri lsd will cope with 300bhp from a YB then? as a semi cheap option, i spoke with a rally car building firm n was recommended a diff etc but its Ł900 and was told Ł1700 for a decent axle build.. i just want to get on the road to start with.
looks the part, im thinkin possibly overkill but its obviously gonna do the job even if went 500bhp (doubt very much i will lol)
http://www.ebay.co.uk/itm/BABY-ATLAS...item2ec0da90d7
Give Lea Atkins a try top workmanship and reasonable prices, just tell him what you want to do with it he wont sell you stuff you dont need
Eigdoog
Sep 13, 2015 05:46 AM
