Escos issue, any helpers?
Hopefully some one can help as its doing my nut in.
I have an Escos shell which is going to be my wrc drift car, all the underside is painted, powdercoated etc and its back on a set of 18" speedlines.
Now i have put all the 2wd bits in place but the front wheels are to far forward which i have discovered is the antiroll bar so i assume i have a 4x4 arb and need a 2wd arb, so will a saff 2wd arb fit????
Any help would be really appreciated.
i take it you have used a 2wd engine cradle? as possibly thats whats caused the front wheels to move forwards as if your using a escos and a 4wd roll bar then the wheels should line up, but there not centre in the arches anyhow and neither are 4wd safs
the 2wd roll bar will bring the wheels into the centre though or get compression struts lol
SMILER258
Sep 28, 2015 09:04 AM
