3 door rollcage same as 2wd saphhire ???
As title will they be the same or will it fit but not quite be in same position ?? Any help would be great peeps
Yes they are, no they aren't,
Depending on which cage you have and which Sierra youve got!! 3door or Saph
They fit fine into the wheel tubs and floors, but the b post part of the cage may protrude forward away from the b post if you are using a Saph cage in a 3 dr, and if it's a 3 dr cage in a Saph then the b post will be further back in the rear door opening!
Hope that makes sense!
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 3, 2015 04:08 PM
dojj
28
Sep 11, 2015 10:00 PM
