Ford Fiesta The Iconic Ford Fiesta started in 1976 and ended in 2023 bringing to a close this great cars run of almost 50 years.
help please
Old Aug 27, 2012 | 09:03 PM
ConnorH453's Avatar
ConnorH453
Default help please
hi a bit new to this was wondering if anyone could help me with a slight problem i have a 1.2 mk5 fiesta about to be converted to a puma and I'm not sure how much bigger to make the brakes or if ill even have to change them has anyone done this before or know any threads that could help.
Old Sep 24, 2012 | 12:23 AM
Black Foci's Avatar
Black Foci
If you are keeping the 1.7 standard, then a set of ST150 front calipers and discs will be a good upgrade. They will fit under 15" wheels too. A better set up is either ST170 calipers and ST170 front discs, or Mondeo Mk3 calipers and ST170 discs, but youll struggle to fit them under anything less then 16" wheels. They are both easy to get hold of parts, there are loads of other options available, Escos front discs and calipers are also a really good set up.
All these bolt straight to the hub, you just have to re-drill the holes in the hubs, i think from 12mm to 14mm. Either way, they just need opening up a little.
