what diff ratio? pictures inside of car
some progress made since these pictures were taken
ok its a 2.0 twincam with standard exhaust and type 9 box with a new clutch
im running an lsd but not sure what ratio
in the wet it just about diffs but is a total no go in the dry the diff is tight
i have another 6.2 diff there from a 4x4 cozzy maybe this would be better
what ratios do you fine people suggest? and where would i find these?
7 inch cradle you see
i could change to a 7 and a half
i have a mark 1 2.8i sitting there its bolt on shafts what would be in this? its a 4wd
thanks for the help folks so something close to 3.9 ratio
The 2.8 will probably have a 3.62, most V6s did. What do you want to achieve? To be able to go round and round in circles? Just get a 3.92 from a 1.8 cvh, fit the drive flanges from your diff, and weld the bugger up. Plenty of smokey sideways driving.
going to take the diff out of my wagon today and crack it open and see what the story is thanks for all your help folks just out of curiousity what ratios are there and what do they come in? may look into changing crownwheels
i seen one on ebay but its crazy money 150 plus postage i think il hold out lol the 4x4 diffs tend to not tighten properly they slacken quite easily my friends have had this problem before my car may be ok with a 3.62 that i have it all depends on whats in the car atm
ok swapped my diff the one that was in was a 3.62 and i swapped it for another tightened 3.62 but it didnt seem that tight not happy 60quid down the drain
was able to diff in 1st gear with 3 in the car
would love to know how to tighten the diffs myself? does any1 know? few chaps i know talk about putting pennies in
was able to diff in 1st gear with 3 in the car would love to know how to tighten the diffs myself? does any1 know? few chaps i know talk about putting pennies in
get a 7.5" one and i ll tighten it for you, it ll be Ł100 but
track.focus'd
Aug 12, 2015 05:53 PM
xr4x4rs
Aug 6, 2015 09:03 PM
