rs1600i
Old Aug 26, 2012 | 08:13 PM
tommytxr's Avatar
tommytxr
why o why do i do it!!!!!
Default rs1600i
Hi just a quick one does the rs1600i and the escort s1 have the same wheels. Got a mate who needs a set of wheels
Old Aug 26, 2012 | 08:14 PM
Nick.W's Avatar
Nick.W
Same but writing on only one spoke I believe.
Old Aug 26, 2012 | 08:32 PM
stevenr's Avatar
stevenr
Easy to tell them apart 16i wheels have writing on 1 spoke and S1 items have writing on 4 spokes.
Old Aug 26, 2012 | 10:09 PM
It's Czech Mate's Avatar
It's Czech Mate
Look the same but arent, as said easy to spot as only writing on one spoke
Old Aug 26, 2012 | 10:10 PM
Roscopeco's Avatar
Roscopeco
P8 Managed S1 with ALS
As above , also centres have RS on the RS1600i ones but S1's are just blank
Old Aug 27, 2012 | 07:28 AM
STeve's Avatar
Super Moderator
my rs16i had the word motorsport on one spoke and a mates S1 at the time did'nt
Old Aug 27, 2012 | 09:02 AM
RstAaron.'s Avatar
RstAaron.
The wheels on my cabriolet have Motorsport on one spoke with writing on 3 others with 1984 on one. (going from memory)
What are they likely to be?
Old Aug 27, 2012 | 09:05 AM
STeve's Avatar
Super Moderator
makes no real difference as quailty was the same its just rs16i ones were made before the S1s were invented
Old Aug 27, 2012 | 10:20 AM
stevenr's Avatar
stevenr
What size are they? Anything other than 15" and they will be accessory wheels i would think.
If they are 15" though and they have Ford motorsport 9057884 on one spoke then they are RS1600i.
If they have writing on 4 spokes they are S1 turbo.
Old Aug 27, 2012 | 10:23 AM
stevenr's Avatar
stevenr
Not strictly true,easiest way to explain is copy this from the RSOC
The outer edge of a S1 Wheel usually refered to as the beading is also significantly thicker than an RS1600i wheel , this can only really be noticed if you put the two wheels side by side, the reason for this is that the rsi wheel was prone to buckling with the wonderful standard of British roads so the S1 wheels were strengthened in this area.
The more observant of you may also have noticed a difference in the spacing of the RS1600i wheel there can be a large gap between the Ford motorsport lettering & the 9057884 Part number these are generally regarded as early production wheels .
Old Aug 27, 2012 | 10:39 AM
RstAaron.'s Avatar
RstAaron.
Sounds like they're S1 wheels then. Cheers mate! Got a set of 5 on the car and only paid £400 for it. Will check when I'm home to make sure things match up.
Benleys
Escort Range
Sep 28, 2015 01:56 PM
MadMac
Oct 10, 2004 12:03 PM
