Ford Range This section is for other models in the Ford range.
Help please Ford Galaxy with starting problem
Old Aug 23, 2012 | 11:13 AM
Gary Baker's Avatar
Gary Baker
Default Help please Ford Galaxy with starting problem
Hi all
I have a Ford Galaxy petrol 1996 2.0 with Intermittent starting problem. Please can someone help its doing my head in Breakdown guy sprayed cold start into air intake and it started so he reckons that its fuel pump but others have said it could be relay/immobiliser lights all come on and engine always turns but sometimes will fire up others it just turns over and the fuel pump doesnt hum. The red light on the door is constantly on when it wont start Thanx Gary
Old Aug 23, 2012 | 06:13 PM
MikeyRobbo's Avatar
MikeyRobbo
PS3 - MikeyRobbo
Switch ignition on so the ignition lights are on and listen for the fuel pump, might be better if someone sits in the back for it, do it a few times, if no noise, fuel pumps dead, check fuses. If the fuse is okay then get looking for a new fuel pump!
Old Aug 24, 2012 | 05:11 PM
Gary Baker's Avatar
Gary Baker
Hi Robbie
Thanx for your reply, could it also be the relay, if so is there a way to check the relay?
Regards
Gary
Old Aug 24, 2012 | 08:41 PM
MikeyRobbo's Avatar
MikeyRobbo
PS3 - MikeyRobbo
Could well be the relay worth a look! Couldn't tell you how to test one though
Zoggon
Aug 10, 2015 10:39 AM
